Fob advice?
Which key do you have? I just converted my OEM 2004 D2 keys into these $9.99 eBay shells and they look 100% authentic
2 Button Remote Key Fob Case Shell for Land Rover Discovery 2 TD5 V8 Repair Kits | eBay
I had tried another cheap eBay FOB in the past but the key blade did not fit well into the plastic case, the kit I just recommended is a perfect (tight) fit for my key blades and even says Valeo on the back
Put your location in your signature, maybe a member can help.
I did the same as FloridaRover, nine dollar fob and used the same circuit board with a new battery. Also had a new key cut off the original as it was wearing out too. That took two tries, one at a hardware store where they failed, then at a lock shop which showed me how the hardware store failed.
Since you don't have any fob at the moment, you'll need someone to interface with the car and sync a new one. There's a guy that advertises on my local craigslist selling the service, with a new key/fob for $130 out the door. Local folks with nanocom will usually do just the programming for $50.
Your other alternative is to go with an aftermarket keyless/alarm setup, but it will probably end up costing just about as much as your quoted prices in the end.
Best bet is calling up a local independent LR repair shop and see what it would cost to get a fob and have it synced. My guess would be $200 or less. The dealership is going to charge you more for the labor, and may give you a hard time about sourcing your own parts.
After calling every locksmith in the city I finally got a hold of the guys at Lamorna Garage in north Seattle. They were super helpful even recommended before I buy a key to stop by and make sure the truck is able to be programmed. If I provide the key fob they can do it for $50. Sweet! stay tuned...
