Fog light bulb replacement question
Hello. I own a 2002 LR Discovery and I am trying to replace the front fog light bulb. I need some help or suggestions. Here is what I found so far.
1) I was able to get at the bulb no problem.
2) When I try to remove the bulb from the plastic holder casing It appears as though the metal prong is glued to the casing.
My question is how do I seperate the metal bulb prong from the plastic casing. And then when I replace the bulb, do I have to glue it?
Thanks for all your help.
artcareer
08-20-2006 05:23 PM
