Fog light lens swap
Old May 1, 2018 | 05:06 PM
zuke's Avatar
Default Fog light lens swap
Am trying to swap these lenses. Have had one baking in the oven at 200 for ten minutes but doesn't seem to be working. Any ideas?
Old May 1, 2018 | 07:32 PM
dtmbinb's Avatar
They sell a complete fog assembly. Why bother with removing a lens?
Old May 1, 2018 | 08:00 PM
zuke's Avatar
Actually I got it. Used a big cut off wheel on a Dremel to run a cut around the outer lip then put in in the oven at 300 for 15. Got it out, cleaned it up, bingo.
Old May 1, 2018 | 08:14 PM
Best4x4's Avatar
Are we talking 03-04 Fog Lights? They simply come apart via several clips in the back, there will be the outer housing with the lens, a rubber gasket and the back center section which contains the reflector. Slides apart allowing you to clean the inner glass lens.
Old May 1, 2018 | 09:40 PM
Sean Maginness's Avatar
I swapped mine out for some Lexus ones. Took a little fiddling and I would say the stock assemblies with LED bulbs put out more light.
Attached Thumbnails Fog light lens swap-922ae58d-7c5f-438b-a2ce-24930e82eb7e.jpeg   Fog light lens swap-f009a2c2-cb8a-4d5c-994a-1d26ec2f9872.png
John Frederick
Mar 6, 2017 07:12 AM
abran
Oct 1, 2013 09:09 PM
honda50r
Oct 24, 2011 11:40 PM
honda50r
Jun 11, 2011 03:36 PM
