Fox vs Bilstein shocks
Old Sep 29, 2015 | 02:05 PM
99Discovery's Avatar
Not on your list, but I have no problems with my OME shocks and steering damper. Lift is supposed to be 2" OME, it was installed before I owned it. Shocks are OME, and I can fit 31.5" tires, so I assume I have what they say I have.
Right now, I'm planning on sticking with OME if I ever need to upgrade the rating of my springs or replace the shocks.
Old Sep 29, 2015 | 03:27 PM
NVDiscovery's Avatar
That is good to know. The OME lift is 40mm or 1.6" but ends up being 2" I hear given stock spring sag. OME offers 3 different front springs which will be my next question. I don't have a steel front bumper or winch so the lightest of the MD spring should do the trick.
Thank you to you and everyone else for the feedback.
Old Sep 29, 2015 | 03:50 PM
OffroadFrance's Avatar
Originally Posted by ZGPhoto
You can absolutely install regular height shocks with +2 springs.
- I would not recommend it
- You can definitely damage the shock by using it as a limiting strap
- you won't get the full use of the spring
- don't
X1 ............ the shock damping and spring rebound need to be matched as does the shock lift length. If you install standard length shocks and +2" springs there is absolutely no height gain only over compressed preloaded springs and hence none or little effective shock damping, the quickest way to kill a shock. As you may be aware, compression and rebound in shocks are controlled by valving which should be matched to the spring rebound therefore any imbalance creates a really bad nasty ride. Suspension tuning for any conditions is not a 'pick & mix' 'cos that's what it says on the box option but a calculated engineering art. I've spent literally hours calculating sprung and unsprung weights, spring rates and shock rebound compensation plus valving and then some in testing.
Some good info here:
Basic Know-How
Shock absorber tuning for Racing
http://www.kaztechnologies.com/wp-co...m-Kasprzak.pdf
Old Sep 30, 2015 | 04:03 PM
I completely agree with shocks/springs as a system which is probably why the OME set up would be the preferred approach for my application.
Thank you for your thoughts.
Old Oct 8, 2015 | 07:58 PM
Faulk's Avatar
I'm about to install FOX shocks on my 04. I'll keep you posted on my thoughts.
Old Oct 9, 2015 | 08:15 AM
What made you pick Fox over another brand? What springs are you using? Looking forward to your Fox feedback.
HI Rover
Oct 19, 2014 11:51 PM
jpschreff
Jul 19, 2014 08:49 PM
evansjoem
Apr 13, 2014 10:34 PM
ebg18t
Apr 15, 2012 10:38 PM
chelo
Apr 13, 2006 02:11 AM
