Crankshaft problems??
Old Oct 8, 2015 | 07:25 PM
Mark G's Avatar
Default Crankshaft problems??
Just curious, I saw a couple Craigslist posts and they indicated the vehicle had the "Crankshaft Problem" but didn't indicate what it was. I haven't talked to the guys yet. Are there issues with the cranks I need to be aware of, or just the usual leaks?
Old Oct 8, 2015 | 08:59 PM
coors's Avatar
I am not aware of any documented mechanical malfunction. However, they are known for CPS "crank position sensor" failure.
Cost. $80 - $90 bucks, an hour or so of your time.
Old Oct 9, 2015 | 05:20 AM
dusty1's Avatar
Same here.... Outside of that you have possibility for same issues as any other... Wear being the biggest
Old Oct 9, 2015 | 05:22 AM
drowssap's Avatar
unless someone had told him the bearings in the lower are junk, that could translate as a crankshaft problem
Old Oct 9, 2015 | 08:25 AM
Mark G's Avatar
Yeah, those are good suggestions. Could also be a CPS too (or unhooked CPS to mask a deeper problem).
Thanks
Old Oct 9, 2015 | 08:45 AM
drowssap's Avatar
if its a d2 put a scanner on it and see if you read any rpms, if no then it a bad sensor
Old Oct 9, 2015 | 11:54 AM
rtonder's Avatar
If the crank sensor is dead or disconnected the engine will not run and there is no backup or limp home mode. The crankshaft itself is very strong, so I'm guessing it may be the crank sensor, and the only pain in the rear task is disconnecting the plug behind the left cylinder head.
Raider TD5
Defender
Feb 28, 2009 01:16 AM
Disco.Jay
Mar 4, 2006 09:08 PM
smi8387
Feb 7, 2006 01:15 PM
JRdisco1
Dec 3, 2005 10:19 AM
triplevod
May 26, 2005 06:27 PM
