Fresh head job, same issue now. Block?
Old May 10, 2012 | 07:10 PM
me 2's Avatar
Default Fresh head job, same issue now. Block?
I had a misfire in cyl 6 with the sloshing noise in the cabin. Found cyl 6 was dead. Pulled the heads and found the head gasket by cyl 6 was blown pretty good. Rebuilt the top end and now again cyl 6 is misfiring. Didnt see any issues with block but that was just looking at it when the heads were off. Could the block be shot?
Old May 10, 2012 | 07:21 PM
NCguy's Avatar
did u check your spark plug wire or maybe your coil?
Did you replace your spark plug wires and plugs while doing the top end?
I had a misfire on 6 and it was a bad wire, you could see where it was arcing against the block.
Old May 11, 2012 | 07:56 AM
me 2's Avatar
Default stuff
I had replaced plugs before the head change and replaced wires during the change. But before the head job did a spark test and found no issues.
Old May 11, 2012 | 09:53 AM
Wires and plus have nothing to do with this issue. Did you send the heads out for a pressure test, resurface and inspection?
If it were mine, I would pull the number 6 plug and smell for coolant, if OK, the I would then do a compression test and if warranted a leak down on #6.
Let us know how that goes, if OK then either you have a bad coil, bad valve or you are back to the engine as an issue and the 2 tests I suggested should find a head or block issue.
Old May 11, 2012 | 01:12 PM
NCguy's Avatar
Disco Mike, I do not know what we would do without you, I really appreciate everything you do for us!!!!!!
Old May 12, 2012 | 03:27 PM
me 2's Avatar
Default Update
I had forgot to clear the codes from before the head job. I went ahead and cleared them now and did a bit of driving with no codes yet. The motor does sound a tiny bit rough though and Im trying to bleed the coolant system of air now. Hopefully no bottom end issues but will see. Thanx guys
Old May 12, 2012 | 04:27 PM
me 2's Avatar
Default Same problem
Cleared codes, CEL back on with 02 and mifire in 6. Lotsa white smoke coming from exhaust.
Old May 12, 2012 | 05:05 PM
If you want to get to the bottom of this, we need to talk, send me your number.
Old Oct 15, 2012 | 08:02 AM
Bighecka's Avatar
What ended up happening with this? I replaced my head gaskets (thanks mike) and everything was fine, now i am getting random misfires on 2 and some white smoke on startup... but i am not missing any coolant, So i dont know what to do with it. I am going to replace the plug wire on 2 tonight and see if that fixes my problem. - ('02 DISCO 2 SE7)
Also just picked up a D110! so pretty pumped about that
Old Oct 15, 2012 | 09:25 AM
I never heard, but it sounds like he has to pull the heads again.
