Front Drive Shaft ? 04 Disco 2
Old Nov 1, 2013 | 08:23 PM
edgarf23's Avatar
Default Front Drive Shaft ? 04 Disco 2
So I went ahead and ordered a new drive this past week with 5 grease fittings to replace the stock one. Now when I rolled under the Disco I realized that the stock one has a grease fitting at the front U-Joint and just behind it on the shaft. No fittings are at the two rear U-Joints. Does this mean it was refurbished at one point in time? Should I even replace or just grease the shaft? I've owned her for 3 years and this is the last thing needed of the maintenance list. O yea 143K miles on her too..
Thanks in advance,
Edgar
Old Nov 1, 2013 | 09:38 PM
Madlands's Avatar
Stock shaft is just as you described your current one. Sounds crazy but, stock has only one ujoint with grease zerk. So you were right to order a new one.
Old Nov 1, 2013 | 10:36 PM
dusty1's Avatar
yep, you can rebuild that one, to have a spare.
Old Nov 1, 2013 | 11:23 PM
edgarf23's Avatar
Thanks a bunch guys. Yea for some reason i was assuming the stock drive shaft would not have any zerk fittings. Does anyone know of a place in Houston Tx that will be able to rebuild the stock one? I guess your right and it would be nice to have a spare just in case.
Old Nov 2, 2013 | 08:19 AM
dusty1's Avatar
check with chrisinhouston, on here. He made recent mention of a place he uses.
https://landroverforums.com/forum/di...e-shaft-62788/
Old Nov 3, 2013 | 05:20 PM
edgarf23's Avatar
Put the new drive shaft in yesterday and everything went smooth. I put the stock one in the box the new one arrived in and I'll keep that one as a spare. Disco drove smooth without any vibrations at highway speeds.
Old Nov 3, 2013 | 10:20 PM
jfall's Avatar
A fellow posted a good D.S. rebuild on here with part numbers and pictures to boot.
DiscoJon
Jul 14, 2019 01:51 PM
RSPTex
Aug 3, 2014 11:43 AM
TripleThreat
Apr 12, 2011 08:58 AM
Night Train
Nov 28, 2008 11:17 AM
yarddawg
May 24, 2007 01:54 PM
