front drive shaft
Old May 12, 2009 | 12:04 PM
lrlover's Avatar
4wd High
Default front drive shaft
how do you remove the front drive shaft from 2002 lr disco II and also where to get a dependable replacement thats not 1000 dollars like the dealer is selling.
Old May 12, 2009 | 12:08 PM
okdiscoguy's Avatar
Remove the nuts holding it on at each end....8 of them total.
When you have it off, take it to a driveline shop and have them re-build it. $200 with balancing. Make sure they replace the u-joints with greasable one's
Tom Woods makes a good replacement if you want to spend more $$...
Old May 12, 2009 | 01:34 PM
If you have a shop rebuild it make sure they also replace the centering ball or it will fail real quick.
Old May 12, 2009 | 04:21 PM
leadfoot's Avatar
Mike, what is the "centering ball"?
Another thing, if you are going to take the shaft to a shop to replace the u-joints, why not take the whole car? I doubt they will give you any credit for pulling the shaft yourself. I myself have changed several u-joints in different cars, never gone to a shop, though I admit that a couple of times, while in the middle of it, I have wished I had paid someone else LOL.
Old May 12, 2009 | 06:40 PM
The centering ball is a ball that centers the two u-joints in the double cardon joint.
A double cardon joint is 2 u-joints side by side, you need the centering ball to keep them alinghed with each other.
If you take in the whole car the shop is going to charge you to remove and replace the drive shaft.
If you remove/replace it yourself you will save a good $50.
Old May 13, 2009 | 01:30 PM
mrossipir's Avatar
I just replaced my front driveshaft...removed it and went to the driveshaft shop and because the yoke was so warn, they could only cut and re-weld the old shaft, and put new greasable u-joints. They wanted 450 bucks to do it. My advice is save yourself the aggravation, buy a new one on ebay, that is what I did and drove the car carefully with the CDL engaged for 3 days. It's an hour to put it in. Here's one on ebay, 2 year guarantee, $325.00 bucks.
http://cgi.ebay.com/ebaymotors/Land-...Q5fAccessories
Old May 13, 2009 | 05:38 PM
okdiscoguy's Avatar
Most driveline shops won't pull the shaft. We have 3 here and none of them will pull it.
Oh and to the last poster- You can't engage CDL in an 02.
Old May 13, 2009 | 05:57 PM
discobob's Avatar
Amen to that. Had all my joints repalced with greaseables, and was still virgin enough to not insist on getting the centering ball replaced. Thirty miles down the road my rig was shaking like a chihuahua, well, like my chihuahua. Anyway, I got lucky and no other damage was done except for a towing bill and more labor at the shop.
DiscoJon
Jul 14, 2019 01:51 PM
TripleThreat
Apr 12, 2011 08:58 AM
94LWB
Apr 28, 2007 02:22 PM
mowthat
Mar 18, 2007 05:41 AM
BMWLR
Sep 28, 2006 10:33 AM
