front drive shaft
Old Oct 16, 2009 | 05:26 PM
jneil's Avatar
Post front drive shaft
I have removed the engine on our DII for a over heat issue and while removing it I remembered something about the front drive shaft needing to be updated. Is there anyway to tell if this has been done? It has a grease fitting in the middle but no grease fittings on the U joints.--------------Jneil
Old Oct 16, 2009 | 06:29 PM
lipadj46's Avatar
Sounds like it has not been done. You either need to rebuild it with greasable u-joints for around $80:
http://static.scribd.com/docs/tkatf9...IAL_VIEW=width
Or have it rebuilt for around $250 or buy a Tom Wood's driveshaft for $350.
Old Oct 16, 2009 | 08:38 PM
Should have a total of 3 grease fitting and one plug, if not rebuild it.
Why are you removing your engine?
Old Oct 17, 2009 | 06:17 PM
jneil's Avatar
Thanks Guys, to answer your question Mike I had to remove the engine because of an overheat issue we had and now have coolant in the oil. I plan to check out the engine and see if it can be salvaged and re-sleeved with tophat liners. As it sits now its not worth much with a bad engine. I will give updates as I go along. JNEIL
Old Oct 17, 2009 | 08:27 PM
bikingteacher's Avatar
Just pull the shaft out and bring it to a driveline shop--they can replace the joints for you and it is really quite cheap--if your motor is running to make it worthwhile.
DiscoJon
Jul 14, 2019 01:51 PM
TripleThreat
Apr 12, 2011 08:58 AM
94LWB
Apr 28, 2007 02:22 PM
mowthat
Mar 18, 2007 05:41 AM
BMWLR
Sep 28, 2006 10:33 AM
