Front drive shaft
Old May 3, 2012 | 11:13 AM
You may have a CDL t/case depending on the production date, what was it?
Have you ever rebuilt a double cardon drive shaft, you will have to replace the centering ball as well as all 4 u-joints if they haven't been grease every oil change.
Old May 3, 2012 | 12:14 PM
30more's Avatar
Don't remember exact date but it was the end of the year 2000 I remember seeing that sticker, that means it 2001 right? That what I have been told
Old May 3, 2012 | 12:16 PM
On on the drivers door area, there is a sticker either on the door or door sill.
Old May 3, 2012 | 04:27 PM
30more's Avatar
Ya that's the one I'm talking about, I will look and get back to you
thanks
Old May 3, 2012 | 08:52 PM
30more's Avatar
August 2000
Old May 3, 2012 | 10:00 PM
driscoii's Avatar
Originally Posted by 30more
August 2000
You should have CDL installed on your truck. Though you will have to climb under it to turn the "nut" on top of the transfer case out put. Search CDL on this site there is alot of info. Shaft is a little tricky to rebuild if you havent built one before. I damaged the new centering ball on my first attempt. $42 mistake.
Old May 3, 2012 | 11:33 PM
30more's Avatar
By taking my front drive shaft out and engaging my cdl what am I actually doing?
Old May 3, 2012 | 11:39 PM
lordmorpheus's Avatar
Engaging the CDL splits torque from the transfer case 50/50 to front and rear driveshafts, instead of whatever ratio the differential in the transfer case allows for when the CDL is not engaged. If you remove a driveshaft, and do not lock the CDL, the vehicle will not move, because ALL torque is going to the end with no resistance (the one w/o driveshaft). Locking the CDL allows power to be sent to the rear driveshaft while the front is removed.
Old May 4, 2012 | 09:06 PM
30more's Avatar
thanks for the info. so got my CDL on now and i went to drop drive shaft with a 14mm and it on so tight that its slipping off the bolt, only let it happen twice then i stopped is there a trick or something because i don't want to round these off
Old May 5, 2012 | 11:06 PM
30more's Avatar
Got it out. We will see how she drives for the next week!
Thanks for the help!
Joe
