Front Drive Shaft
Old 10-27-2013, 11:32 AM
jalodge's Avatar
Default Front Drive Shaft
When I went to grease my drive shaft I found that the U-Joint closer to the front axle had worn through this piece and is sticking out. I have been looking online but can't find it. Does anyone know what this is called or where I can find it? Do I need a new drive shaft?
Old 10-27-2013, 01:00 PM
acg's Avatar
acg
acg is offline
The piece which you circled in the pic is known as the double cardon joint.
I believe all you need is to replace the cups and bearings for the universal joints:
Land Range Rover Classic Discovery Defender Universal Joint
There are lots of previous threads about the different manufacturer u-joints which are preferred by posters.
Alternatively, you can chose to replace the entire front driveshaft. This is what I used:
Land Rover Discovery 2 II Heavy Duty Front Driveshaft Drive Shaft Propeller TVB000110 TVB000320
There are youtube videos which shows you the different ways for replacing U-joints.
In the meantime, do NOT drive your Disco. A broken front driveshaft will more than likely pop a hole into your transmission when driven.... which will lead to mucho bucks to replace the entire transmission.
Good luck!
Old 10-27-2013, 03:20 PM
jalodge's Avatar
It is not the U-Joint. Where can I get a double cardon joint?
Old 10-28-2013, 05:13 PM
jalodge's Avatar
Here are some pictures of what I am talking about.
Attached Thumbnails Front Drive Shaft-20131028_180330.jpg   Front Drive Shaft-20131028_180336.jpg   Front Drive Shaft-20131028_180344.jpg   Front Drive Shaft-20131028_180412.jpg
Old 10-28-2013, 06:53 PM
pinkytoe69's Avatar
The U-joint broke.
If the shaft itself isnt damaged you could just replace all of those, but it might be easier and wiser to just get a new shaft.
Old 10-28-2013, 06:58 PM
jalodge's Avatar
Do you know where I could get that double cardan?
Old 10-28-2013, 07:09 PM
pinkytoe69's Avatar
Doubt you can get pieces of the shaft...maybe RoversNorth, but there is no point.
The cost of that plus 2 u-joints plus the centering ball (not to mention the PITA of dis/re-assemble) is gonna be getting close to the $220 for a full shaft from Lucky8.
Old 10-28-2013, 07:27 PM
antichrist's Avatar
The part that's damaged (aside from the u-joints) is called a center yoke, or 'H' yoke. You would only be able to get one at a driveline shop. Or someone breaking Land Rovers.
If I were in your position I'd just go ahead and get a Tom Woods or Great Basin Rovers HD front propshaft.
Old 10-28-2013, 07:43 PM
jalodge's Avatar
Would this part not work?
2-26-497, 1310 Series H Yoke
Old 10-28-2013, 09:14 PM
909wheeler's Avatar
It would work but keep in mind, you will need to have your shaft balanced when all is said and done. Cheaper to go with a used shaft and rebuild that, or buy a new one.
Quick Reply: Front Drive Shaft
