Front Drive Shaft
When I went to grease my drive shaft I found that the U-Joint closer to the front axle had worn through this piece and is sticking out. I have been looking online but can't find it. Does anyone know what this is called or where I can find it? Do I need a new drive shaft?
The piece which you circled in the pic is known as the double cardon joint.
I believe all you need is to replace the cups and bearings for the universal joints:
Land Range Rover Classic Discovery Defender Universal Joint
There are lots of previous threads about the different manufacturer u-joints which are preferred by posters.
Alternatively, you can chose to replace the entire front driveshaft. This is what I used:
Land Rover Discovery 2 II Heavy Duty Front Driveshaft Drive Shaft Propeller TVB000110 TVB000320
There are youtube videos which shows you the different ways for replacing U-joints.
In the meantime, do NOT drive your Disco. A broken front driveshaft will more than likely pop a hole into your transmission when driven.... which will lead to mucho bucks to replace the entire transmission.
Good luck!
Good luck!
Doubt you can get pieces of the shaft...maybe RoversNorth, but there is no point.
The cost of that plus 2 u-joints plus the centering ball (not to mention the PITA of dis/re-assemble) is gonna be getting close to the $220 for a full shaft from Lucky8.
The part that's damaged (aside from the u-joints) is called a center yoke, or 'H' yoke. You would only be able to get one at a driveline shop. Or someone breaking Land Rovers.
If I were in your position I'd just go ahead and get a Tom Woods or Great Basin Rovers HD front propshaft.
