front drive shaft broken
Just install the new remanufactured transfer case about a month ago. Wife is driving the disco home last night and car started to vibrate bad...then clunking noise...then it stop moving. look under it and the front drive shaft broke at the transfer case joint. THoughts?
It's a 04 Disco II How would know if the tranny got damage. Broke going lesss than 5 mph. It start making a noise then put it into the drive way. then was inching up and then no more. Mike do you have an old laying around you might want to sell brother?
Do you have a blood red puddle the size of Lake Michigan under the truck?
If so you need a new transmission, if not you need a new driveshaft.
www.roverlandparts.com
Do a search on the forum for "front drive shaft" or "double cardon"
I had the same thing happen to me. The OE shaft is not serviceable, it gets dried out by the transmission and cat heat. I replaced mine with a custom servicable one from tom woods it bolts right on no mods needed works great.
Good price for a used drive shaft, but it should still be rebuilt before installing.
