front drive shaft broken
Old May 14, 2009 | 01:39 PM
melmanc55's Avatar
Default front drive shaft broken
Just install the new remanufactured transfer case about a month ago. Wife is driving the disco home last night and car started to vibrate bad...then clunking noise...then it stop moving. look under it and the front drive shaft broke at the transfer case joint. THoughts?
Old May 14, 2009 | 01:40 PM
DI or DII?
Old May 14, 2009 | 02:28 PM
If you have a D2 and haven't read about the front drive shaft failures, you need to spens a little more time catching up.
What year is your truck? Did she damage the tranny?
Old May 14, 2009 | 03:09 PM
okdiscoguy's Avatar
It is an 04, from previous posts. It has close to 100K, and I would bet the front shaft had not been built.
Old May 14, 2009 | 03:38 PM
melmanc55's Avatar
It's a 04 Disco II How would know if the tranny got damage. Broke going lesss than 5 mph. It start making a noise then put it into the drive way. then was inching up and then no more. Mike do you have an old laying around you might want to sell brother?
Old May 14, 2009 | 05:49 PM
ryanD2's Avatar
I have a front DII driveshaft, had about 75k on it when i replaced, there was no play in it just went about putting one in that had zerks. Im if interested.
Old May 14, 2009 | 06:14 PM
Ceawl under the truck and look at the transmission, is there a big hole?
Do you have a blood red puddle the size of Lake Michigan under the truck?
If so you need a new transmission, if not you need a new driveshaft.
www.roverlandparts.com
Do a search on the forum for "front drive shaft" or "double cardon"
Old May 14, 2009 | 10:51 PM
troysdisco's Avatar
I had the same thing happen to me. The OE shaft is not serviceable, it gets dried out by the transmission and cat heat. I replaced mine with a custom servicable one from tom woods it bolts right on no mods needed works great.
Old May 14, 2009 | 10:55 PM
tornado_735's Avatar
Hey spike, should I post the pictures? LOL!
Old May 15, 2009 | 09:58 AM
Good price for a used drive shaft, but it should still be rebuilt before installing.
