Front Drive Shaft Care
Old Mar 16, 2015 | 12:22 PM
jfall's Avatar
Woah. I never greased my centering ball.
Well new owner will hopefully.
Old Mar 16, 2015 | 12:41 PM
Rover144's Avatar
...but, if you don't want to spend on a rebuild or replacement, can you just slip a needle fitting on your grease gun into the u-joint and pump in some moly grease??
Old Mar 16, 2015 | 02:00 PM
schwaggy's Avatar
Originally Posted by dusty1
the needle is to stick in the pivot gap, but if the ball is greasable you can drop that end of the shaft and articulate the joints. you should then see this.....
and the fitting below, far right, will push grease in the centering ball zerk, itself. (the thicker needle looking fitting will work too)
Thanks Dusty!
Anybody know what centering ball BPU uses in their shafts?
Old Mar 16, 2015 | 02:06 PM
dusty1's Avatar
Originally Posted by schwaggy
Thanks Dusty!
I have a busted up failed bpu unit on my shop floor. I can look tonight and see if it has any visible stamping
Old Mar 16, 2015 | 03:08 PM
bballjames's Avatar
Dang... dusty, how did it fail? is it the tatton rebranded drive shaft?
Old Mar 16, 2015 | 03:14 PM
dusty1's Avatar
it is the heaviest duty one that they offer.....centering ball imploded and it was still full of grease. pulled it apart and center spring was not present.....so it be a guess as to why it failed......@ less than 10k miles
Old Mar 16, 2015 | 04:33 PM
schwaggy's Avatar
I installed my BPU shaft at 90,225mi - at 96,240mi the CB almost gave out. Shop told me there was no grease in it. Now, would 6000mi do this? I'm not sure, but there ya go...
Hence the reason I really want to inject more grease in there. I'm at 101K now.
Old Mar 16, 2015 | 04:49 PM
bballjames's Avatar
well my only hope is the quality control was better before BPUtah starting selling them... haha i bought mine on ebay from "Tatton" drive line shop in SLC... now sold by BPUtah i believe. shafts on their website look exactly the same as the one i got a few years back
I haven't had any issues with it... yet...
Old Mar 17, 2015 | 07:22 AM
drowssap's Avatar
gease it mon. wed.fri & 2x on holidays
Old Mar 17, 2015 | 07:37 AM
Rover144's Avatar
jfall: Why not just leave the grease fitting in place? Can you provide a picture of what you are referring to?
