Front Drive Shaft Fear
Old Nov 9, 2008 | 07:22 PM
alphawolfman's Avatar
Default Front Drive Shaft Fear
Hello all, this rebuilding of the front drive shaft with greasable joints, etc has really got me concerned. I have owned a 2000 Disco2 with 108K miles, runs and sounds good, NO warning lights on , all O2 sensors and mass air flow replaced, coil packsge, etc.. We just got back from running the roads over to Boone, North Carolina and put over 300 miles on it today. Drove like a champ.Anyway, I presume it is easy to tell if the drive shafts have been replaced?? Anyone have any pics to show after this has been done? Appreciate any advice.
Old Nov 9, 2008 | 07:26 PM
Goose_Cat's Avatar
Default RE: Front Drive Shaft Fear
Just crawl under the truck and check or zerk fittings on each u-joint. If you have them the shaft has been replaced already just make sure you grease every fitting. If not then you are on borrowed time, these shafts usually fail around 70k.
Old Nov 9, 2008 | 07:47 PM
PalmettoDisco's Avatar
Like he said, look for the grease fittings (zerks) on the double-cardon joint. It's the double set of u-joints on the front driveshaft attached toward to the transfer case\transmission. Also, with that many miles you probably want to check the rotoflex rubber doughnut, on the rear driveshaft, for wear.
Old Nov 9, 2008 | 07:55 PM
You will get dirty, but like Goose said, feel around the funny looking ends of the driveshafts. Feel around for a nipple, here is a pic of a u-joint, in the middle of the snap rings is the nipple that you will be looking/feeling around for.
It screws into the middle of the u-joint, it only sticks out about a 1/4 inch.
http://www.roverparts.com/Parts/TVC100010.cfm
Make sure they get greased at every oil change.
Old Nov 9, 2008 | 09:49 PM
Aj6543's Avatar
Can someone post pictures? I have a 2000 Disco with 76k. I am scared that my car is going to fail. I don't even know what the driveshaft looks like. Can someone provide more detail?
Old Nov 9, 2008 | 09:57 PM
jmrivera's Avatar
http://www.roverparts.com/Parts/TVB000110.cfm
Just get your rebuilt... If you post your location, maybe someone can point you to a good shop!
Jonathan
http://www.roverlandparts.com/1999-2...ewoempart.aspx
This is what the front driveshaft on a DII looks like.
Just take the truck to a shop and have them look for the grease nipples.
Old Nov 9, 2008 | 11:01 PM
Aj6543's Avatar
I am in Washington, DC. Where is a good shop that can help me with this?
Old Nov 9, 2008 | 11:05 PM
snowdude's Avatar
how much dose a rebuild cost? dont think mine was rebuilt,ill have to look tommarow.
Old Nov 9, 2008 | 11:33 PM
Disco2Guy's Avatar
Rebuilds can be around $200-$300. Here's a picture of the rebuilt double cardon..
