Front Driveshaft - Cracked Rubber Seal
Old Jun 3, 2013 | 06:15 PM
pinkytoe69's Avatar
Default Front Driveshaft - Cracked Rubber Seal
As title says, the outer seal on the centering ball section is showing age. It is cracked through to the inner metal.
Googling doesnt come up with much about this issue. I did find stuff that says the Tom Woods doesnt have a seal, but thats probably cause the ball is greasable.
I was gonna fill it with liquid tape. Should I find a replacment somehow?
Old Jun 3, 2013 | 08:41 PM
NickAdams's Avatar
Mine looks just like that. I filled it with grease, and plan to keep a close eye on it until the Minister of Finance approves a re-build.
Old Jun 3, 2013 | 09:28 PM
pinkytoe69's Avatar
Cool. I liquid taped it. Looks better than it was at least.
Old Jun 4, 2013 | 08:41 AM
Or, you can order the rubber seal and do it right.
Old Jun 4, 2013 | 11:09 AM
pinkytoe69's Avatar
From where?
Old Jun 4, 2013 | 11:22 AM
dpaller's Avatar
HAHAHA I had to approach the same person yesterday after a failure on my D2
Old Jun 5, 2013 | 08:02 AM
richief556's Avatar
did you ever find out the part number for this broken seal?
I have the same issue.....
Old Jun 5, 2013 | 09:00 AM
jafir's Avatar
I think there might be some confusion. The seal posted, I've never seen available anywhere. The seal that the tom woods shaft does not have that the factory shafts do have is the gaiter: http://www.rovahfarm.com/images/TVE100000.png
Old Jun 5, 2013 | 09:43 AM
04duxlr's Avatar
Here's a listing of part numbers depending on what series joints you have: http://www2.dana.com/pdf/J300-P5.pdf The seal is listed as the "slinger." It looks like the 2-86-418 is the correct one, but if someone has their propshaft out they can confirm it. You can get one online http://www.actionmachineinc.com/2-86-418.aspx or probably from any local driveline shop.
Old Jun 5, 2013 | 09:49 AM
richief556's Avatar
I've seen that gaiter for sale on Atlantic British. Is it a difficult fix?
