Front end shake
Mike just to make sure we are on the same page: when you say driveshaft are you referring to what rave calls the driveshaft which is the solid shaft located inside the axle housing, or the shaft connecting the.center differential to the axle that rave calls a prop shaft, but is comply referred to on american vehicles as the driveshaft?
Read this: https://landroverforums.com/forum/ge...02/#post164811
Thanks Anti, Mike, and others. I found the 4 fittings there now and just did a 2:30 am run to the local walmart for some grease so I can hit those first thing. I'll replace the u joints in just a few weeks.
Ok keep your fingers crossed. I have my parts, page 600 in the rave book marked, and hopefully the rain will stop in a few hours. Time to replace the up joints in the front tonight, and the rear if I still have time.
