Front End Squeak
Old Oct 15, 2007 | 04:47 PM
98roverguy's Avatar
Default Front End Squeak
Sounds like a wheel bearing going out. Just a constant high pitched squeak at low speeds (15-30 mph) from the right front end. Stops when I hit the brakes. Any ideas?
Old Oct 15, 2007 | 06:40 PM
okdiscoguy's Avatar
Default RE: Front End Squeak
brakes? pull your pads and spray some squeal stop on the back of them. See if it goes away. Or you could be cool and jump out while it's rooling to see where the squeal is coming from. I think the rappers call it "ghost riding the whip"?
Old Oct 15, 2007 | 07:35 PM
I agree, not enough miles on your truck for new hubs. If it is the brakes, you will probably need pads and rotors, possibly even caliper kits.
Old Oct 15, 2007 | 08:49 PM
ajh's Avatar
ajh
When you pull the pads if it looks like there is enough material take a file to the edges and put on a bit of an angle. They come this way from the factory and will not vibrate as much. If your pads and rotors look good you'll need to check your caliper pistons to see if any of them are seized, if they are it's time to rebuild them which isn't hard but can be a bit of a pain, personally I hate bleeding brakes even on a motorcycle I haven't done it on the disco yet but I need to soon since I had to shift a banjo a few days ago.
Also, check to see if anything is rubbing. There's an off chance that something got wedged between your brake shields and your rim or something similar.
Old Jul 18, 2012 | 06:30 PM
thewheel69's Avatar
I've got something similar going on in the front left. It sounds like the brake pads are dragging and there is a notch on the disc that makes it kind of tick as well as squeak... its rotational and matches speed of the wheel... its super obnoxious and I cant for the life of me figure out what is going on.
1. I inspected the caliper for any wear that would indicate rubbing... all good...
2. The rotor is fine as well... not warped
3. the pads have tons of material left... they are Aekobono
Is it the hub/bearing?
Please help guys... this makes going down 4X4 trails with the windows down just plain nuts!
Thanks in advance
MrValingo
May 15, 2015 09:43 PM
swak6287
Mar 27, 2015 11:04 PM
kwazadilla
Aug 19, 2013 04:14 PM
TheUninformedOwner
Freelander
Mar 26, 2009 11:39 AM
sna77
Nov 18, 2008 06:23 PM
