Front End Vibrates when Accelerating
Old Jan 20, 2020 | 06:52 AM
toddd10's Avatar
6th Gear
Default Front End Vibrates when Accelerating
Hi All,
Just received delivery of a 2002 Land Rover Discovery 2 with 44k miles. The front drive shaft is new but the vehicle shakes when accelerating - gets worse and louder as I accelerate. Any thoughts?
Todd
Old Jan 20, 2020 | 08:18 AM
Sixpack577's Avatar
I would check tire condition, psi, and have them balanced.
Eliminate the simple and inexpensive things first.
Worn, low, and/or out of balance tires will cause alot of vibrations, and they can come and go depending on speed.
Old Jan 20, 2020 | 08:40 AM
ahab's Avatar
Try revving the engine in neutral as well to see if the cooling fan is a contributor.
Old Jan 20, 2020 | 09:27 AM
Sixpack577's Avatar
+1
and you can also remove the belt to rule out the fan, tensioner, and accessories.
Old Jan 20, 2020 | 09:55 AM
NewToTheTwo's Avatar
An 02 with 44k miles might have VERY old tires - potential dry rot and out of round conditions.
There should be a date code on the sidewall to decipher.......
Old Jan 20, 2020 | 10:13 AM
frostythor's Avatar
Default get the grease gun out
I think I would be looking at the prop-shafts,front and rear, grease them up first may be dry.,,,, if the vibration is less, the then think about , replacing the UJ, or a re-balance on them
Old Jan 20, 2020 | 06:50 PM
toddd10's Avatar
6th Gear
Thanks all. I'm a new member and posting for the first time. The tires are new but I thought the wheels could be bent or wobbling so had my son drive it around while I watched and but look good. The front drive shaft is new also but maybe it wasn't installed correctly - although that seems like a pretty simple job. Taking it to a Land Rover specialist Thursday and will update.
Old Jan 28, 2020 | 07:00 AM
toddd10's Avatar
6th Gear
Looks like when the front drive shaft broke it did some internal damage to the transmission and transmission case. New transmission around $3k installed.
Old Jan 28, 2020 | 12:48 PM
frostythor's Avatar
3k, wow, I think I would be looking on E bay in the UK they go for 200 UKP, then have a full professional rebuild with a 12 month, 12k miles,guarantee a couple of hours to take your out straight swap,
after all that's what this site is all about keeping the Old Girls going at a reasonable expense, and not lining the pockets of others unless it absolutely required
Old Jan 28, 2020 | 01:40 PM
Llamasayswhat's Avatar
3k installed is a great price for any shop to install a transmission
