Front Engine Oil Leak
I have a good oil leak coming from the front of my engine (4.6L). What are the most common causes of this? Where should I look? I removed the plastic cover so I can get a better look and I can see oil slowly coming down from behind the crankshaft pulley. Obviously it could be coming from above that so I’m not sure. Any feedback would be appreciated.
I'd do the front crank seal. I had a similar leak and when I changed the front crank seal it solved 95% of the oil leaking (it's still a 21 year old rover ha). The old seal was rock hard so it made sense why it wasn't doing anything. I'd also look at putting a speedy sleave on the crank pully, mine had some shallow grooves which is probably letting the new seal leak a bit. I got lucky and the whole thing took 30 minutes but it really comes down to if your fan clutch wants to come off the water pump or not. I'd start soaking it in PB a couple days before you start.
Any idea on what a main seal fix will set me back?
If you do it yourself it’s cheap, even if you need a speedie-sleeve. If you’re paying a mechanic it won’t be huge either, but it will take him a few hours, mainly getting access. I don’t have anywhere near as much experience on these as some of the guys here, but I think chances are you won’t need the sleeve.
