Front hub squeal
Old Apr 10, 2010 | 08:18 PM
Torancis_LR's Avatar
Default Front hub squeal
Ever since I had my brake kit installed, I am getting a squealing sound from the front passenger side. The mechanic really beated the front rotor to death b/c they say it "was really rusted"
Here is a sound clip:
(from user discoinchatty)
http://www.youtube.com/watch?v=ldnwQ...layer_embedded
I have been doing some reading here on the forum and so people said to stop driving the truck? Is it necessary, if indeed the problem is in the hub and will need replacement?
I am planning on purchasing a pro line hub from Rovers North.
Also, I read that if the hub is the problem, the 3 amigos will light? My 3 amigo has not lite yet. Should I wait until the light to come on?
I appreciate your help. Also, I have UrbanP's link http://www.discovery2.co.uk/
Old Apr 10, 2010 | 08:47 PM
I couldnt hear anything.
If the hub seizes you could crash and you will be stranded.
If there is enough play in the hub to put the exciter ring out of alignment with the ABS sensor then the 3 amigos will come on.
Have you looked into a used hub?
Old Apr 10, 2010 | 08:52 PM
kenk's Avatar
If they really abused it, sounds like might be wheel bearings. Check rovah farm, $75 cheaper than rovers north
Old Apr 10, 2010 | 10:38 PM
An used hub from roverland parts is $239 while a brand new one from rover north is $299.
I will be ordering them on Monday, hopefully the hub will last for about a wee.
Old Apr 10, 2010 | 11:18 PM
discoinchatty's Avatar
Did yours start making that sound again torancis? I haven't heard it in mine in since that day, everything seems to be ok for now. I actually found quite a bit of dried mud stuck to my front left brake caliper and cleaned it out, thinking that may have been the cause of it.
Old Apr 11, 2010 | 09:20 AM
discoinchatty, yes the sound came back, this time much louder. I maybe should take off the tire and see whats going on.
Old Apr 11, 2010 | 09:36 AM
Danny Lee 97 Disco's Avatar
I would not be using a mechanic that has to beat on it that hard to remove it.
Find a new mechanic or learn to do it yourself.
Old Apr 11, 2010 | 10:16 AM
Danny Lee, you are absolutely right, my lesson learned.
I will keep everyone updated as to what I find.
Old Apr 13, 2010 | 07:14 PM
Default UPDATE Everyone!!!
So, after taking the wheel off, putting it back on and checking for play, I came to the conclusion that the squeal is the new EBC greenstuff making the noise.
Many people said the greenstuff is noisy but I am not aware how a brake squeal sounds like.
The sound stops when the brake rotor and pads are warm. So, no problem!
Old Apr 13, 2010 | 07:44 PM
I did not realize that you had put new brakes on.
kwazadilla
Aug 19, 2013 04:14 PM
sparky
Apr 25, 2011 08:58 AM
bikingteacher
Feb 10, 2010 07:06 PM
mike.howard
Jul 3, 2006 07:27 PM
BigMike
Mar 30, 2006 09:45 PM
