Front main seal...again
Old May 1, 2016 | 09:43 AM
mark d's Avatar
Default Front main seal...again
A year ago I replaced the front seal. The harmonic balancer had small grooves warn by the old seal. I put the balancer in my lathe and polished the mating surface, replaced the seal and put it back together. The leak is back and I pulled it apart yesterday. There are sleeves made that slip over the old seal surface and provide a new polished stainless steel surface for the new seal to ride on. Speedi Sleeve is one made by SKF. I am doing the research now to find the correct one. If anyone has fought this battle and can help with advice, please let me know. I will post what I find to help others with the same issue. Thanks.
Old May 1, 2016 | 10:04 AM
Charlie_V's Avatar
Mark I haven't had a grooved surface but I did look into speedi sleeves when I had a persistent leak. Before I settled on which one to get, though, I found that my crank pulley was vibrating. I was just standing next to the truck while it idled with the fan off and noticed it. I found a tiny bit of the damper rubber had pressed out, but it was inducing a huge wobble. I had a spare so I swapped them and it fixed the leak.
NOT saying that's your problem but it is free to check.
Here's what mine looked like.
Okay I can't find the photo. But the rubber was only slightly pressed out on the back.
Old May 1, 2016 | 10:58 AM
OverRover's Avatar
Old May 2, 2016 | 09:56 PM
mark d's Avatar
Thanks Over Rover, that is the same SKF part number and came up with. My local industrial house had it in stock. I installed the new seal (FelPro from NAPA) and pressed the Speedi Sleeve on with my press. Charlie V, I share your ticking frustration. I am installing a spare rocker assembly now. This is after new lifters and push rods. Yes, it is embarrassing. I will let you know what happen
Old May 2, 2016 | 10:13 PM
Charlie_V's Avatar
Please do. I've got rockers aplenty. The ticking is maddening. Like a countdown on a bomb.
Old May 8, 2016 | 09:38 AM
mark d's Avatar
Default all back together
It went back together yesterday without too much pain. New push rods, new lifters, used rocker assembly and it still ticks. I am starting to think my oil pressure is dropping down at idle. May be time to look at a top hat.
SSchultz
May 2, 2020 08:42 PM
lr3guyjoe
Nov 19, 2015 01:42 PM
aemnky606
Mar 23, 2015 06:50 AM
outdoor7or24
May 21, 2012 08:34 AM
CANAMDiscovery
Apr 5, 2012 11:30 PM
