front output shaft
front output shaft
So I've had some play in my front driveshaft area and started looking around. The driveshaft is solid but the front output flange thing has play in it.
Earlyrover told me to tighten the nut securing it. I'm staring at it and don't have a big enough socket for it. So first question - what size is this thing? And how tight should it be??
From memory I believe the nut is 24mm and the torque setting is: "Tighten to specified torque, which is 146-179 NM" (or very, very tight in other words)
RAVE Manual = Drive flange nut 148 Nm (109 lbf.ft)
For tx front output shaft and casing check out RAVE Manual Section/page 41-8.
