Front shaft question
Old Mar 9, 2023 | 10:51 AM
BraziliaNut's Avatar
Thanks guys. Yeah Lucky8's is not greasable at this time. According to their customer service, there was an issue with manufacturing and it will take months before that option is available again. Good thing because I was ready to buy it, before I read your comments. I ended up getting a TrueDrive from carparts.com. Couldn't find a whole lot of info about them: https://www.carparts.com/details/Lan...EPL545503.html. Let's hope it's not a piece of crap... I'll take my old one to my local drive shaft repair shop to see if it's worthy to put a set of Moog greasable joints in it, as suggested by Extinct, and keep it as a spare.
Old Mar 9, 2023 | 12:44 PM
ahab's Avatar
If you can get the factory shaft rebuilt, I would use that and keep the TrueDrive as a spare. The TrueDrive is most likely a reman'd unit, but who knows its country of origin. At least you know the original is a quality part so as long as the shop who does the work is reputable then I would choose that one over an unknown reman.
Old Mar 10, 2023 | 05:51 AM
NVDiscovery's Avatar
https://gbrutah.com/shop/drive-shaft...2-driveshafts/
Again, many of us have had great success with the GBR rebuilt drive shaft. Mine has worked for over 70k miles. Plus, they are a wealth of information on all things Land Rover and wonderful to work with on any issues.
Old Mar 13, 2023 | 01:37 PM
Thanks for the info! I was wondering, if the root cause of this problem is the proximity between the catalytic converter and the front shaft, has anyone tried to have a heat shield between them? That would probably alleviate this issue significantly right?
Old Mar 13, 2023 | 02:29 PM
jastutte's Avatar
that is exactly the cause of the issue. well, that and the OE shaft not being greasable.
i think the cat should have a heat shield on it from the factory. still, the shaft is pretty damn close to the cat, so, not sure how much good it does.
Old Mar 13, 2023 | 03:26 PM
I did a quick check and found a couple of products to wrap the cat converter, I'll investigate further: https://www.heatshieldproducts.com/c...er-heat-shield
Old Mar 14, 2023 | 05:08 AM
Extinct's Avatar
Several people have installed heat shields. I fabbed mine from aluminum exhaust duct from Home Depot. TiminNova found one on Amazon that looks good.
Old Mar 14, 2023 | 08:09 AM
I believe that the other issue is that the A/C condenser drains onto the front drive shaft as well which adds to the environmental stress.
Old Mar 14, 2023 | 10:17 AM
YETIX's Avatar
I'd be curious to see what Tim found. I see a couple of generic heat shields on Amazon.
Old Mar 14, 2023 | 07:27 PM
Extinct's Avatar
A search should turn it up, or message him directly.
