Front Spring Compatibility?
Old Oct 4, 2011 | 10:43 AM
rhyslegge's Avatar
Default Front Spring Compatibility?
I have read many threads on this, but I cant seem to nail it down, any help would be appreciated! My stock front springs are sagging to the point that every bump I hit is teeth chattering. I want to maintain as close to stock ride height with new OME springs and shocks, I understand I can go about 2 inches without screwing up anything. Catch is I have ACE and rear air springs. I am going to put in new air bags (leaking) and shocks all around, but is there an OME kit just for the front that will play nice with ACE? I want to keep ACE and rear air bags, so coil conversion and ACE removal is not an option. Thanks all, I appreciate it!
Old Oct 4, 2011 | 11:22 AM
drowssap's Avatar
Disco Mike is probably your best bet as he has ACE in his rig and has full understanding of the SLS.
I believe you can go 2-3 inches lift and it will not effect your ACE system. For the bags you would have to get 2 inch spaces to keep the truck level.
I have not seen any lift kits for ACE & SLS; I have look, as I have the same set up.
I believe we have to buy the parts seperately, ie. front springs, airbags and a shock/ stablizer kits.
Toddco has the air bags spacers and Arnott makes the air bags, Arnott say they do custom bags so maybe you dont need the spacers, front spring and shock kits can be found anywhere.
Let me know how you make out i'm heading down the same road.
I kind of sick of the teeth chattering myself, I have 90+ on what look to be original shock and springs.
Land Rover Discovery Series II 1999.5-2004 Suspension Lift Kits
Air Bag Suspension Systems, Air Suspension Kits - Arnott Air Suspension Systems
Old Oct 4, 2011 | 01:57 PM
humroot's Avatar
I have a 2001 DII with ACE and SLS. I have the OME 751 springs (for the DI) in the front which is about a 3" lift. For the rear, I used a set of ToddCo SLS spacers. No issues at all with ACE or SLS.
Old Oct 4, 2011 | 03:22 PM
Pretty much the same thing I did, I just used the RTE spacers instead of the ones from Toddco.
Make sure to replace your leaking bags with Arnott bags for better performance and warranty.
Old Oct 4, 2011 | 04:38 PM
rhyslegge's Avatar
Talking Parts
Excellent, I will be placing several orders tonight, I expect! Glad to see others have done the same with this convoluted setup. Thanks a bunch!
stankonia20
Oct 9, 2009 11:24 AM
southfloridadiscoII
Jun 18, 2009 08:48 AM
jimrrsport08
Jul 23, 2008 07:22 PM
jimrrsport08
ROAMING WITH FRIENDS
Jul 11, 2008 04:15 PM
cold_surfer
Feb 5, 2008 07:04 AM
