Front Sun Roof Repair - part needed
Old Jan 11, 2023 | 01:42 PM
bjordan's Avatar
Default Front Sun Roof Repair - part needed
Hi Folks. I have taken the plunge to fix the front sun roof leak(s) and fix the front sun roof itself so it opens and closes. I've gotten a new working motor, but the cable assembly is frozen and one side is cracked (someone other than myself has been in this area before.
What is the official name of the cable assembly that the motor drives? I need to replace mine - cable, brackets, sliders, etc - the whole assembly..
Thank you in advance for the help!
Old Jan 11, 2023 | 02:22 PM
brivalen's Avatar
I bought 3 used sunroofs and was able to swap parts around to get both of mine working.
there are a few Land Rover breakers that will send the to you. OEM rails are still available but crazy $$$. Last I checked like $700
Old Jan 11, 2023 | 03:56 PM
keninnc's Avatar
I replaced mine also due to the previous owner had sealed it shut.
It's actually easier to find a salvage yard and remove the 14 Torx screws that hold it in and just replace the entire unit. Also sunroofs are relative cheap from a salvage yard.
You will need to partially drop the headliner.
Old Jan 12, 2023 | 03:45 AM
frostythor's Avatar
If your going to do it dont just do the front take the headliner down and do front and rear, remove both the sunroof and reseal them do the job 100%, or it will come back to bite you again with a new leak
Old Jan 12, 2023 | 09:11 AM
bjordan's Avatar
Thanks everyone. I found an entire, used assembly on ebay that was tested from a running vehicle and did not leak. The pan even has the unbroken drain line spigots. I didn't necessarily need the glass, but this assembly will have cleaner glass as the PO tried (and failed!) to caulk the entire sunroof. The back sunroof works fine and does not leak. I'll report back if there are issues with the new assembly. Thanks to everyone!
Old Jan 12, 2023 | 01:50 PM
XRAD's Avatar
seal up the front black plastic drain trays where they meet the metal frame before installing the sunroof....
Old Jan 12, 2023 | 02:49 PM
bjordan's Avatar
I sure will!
Old Jan 12, 2023 | 03:48 PM
nashvegas's Avatar
As for the tracks, you can still buy them new. About 600-800 from LR.
See images at bottom, from Land Rover Monthly in 2014.
4 places to seal up:
1) between the plastic frame on the roof and the roof (it's originally held by double sided tape, you want to run a bead of black sikaflex etc under it after removing and cleaning up the paint on top of the truck)
2) the plastic sunroof drain tube trays/nozzles - remove and reseal them to the black metal frame, buy new plastic trays if needed.
3) seal the metal frame to the top of the truck (ie run a bead around the black metal, then lift it up to the roof, and then you'll use the mounting screws)
4) The rubber seal between the glass and the upper plastic frame. May need to be replaced. There is only the aftermarket Britpart seal available, which I've found kind of sucks compared to the original. it's fine but original LR seal which is no longer avail is better.
It's quite easy ... once you disassemble everything. And laughably I have a D2 in the garage w/ the roofs & headlining out waiting for all of these fixes.
Old Jan 12, 2023 | 03:50 PM
bjordan's Avatar
Awesome - Thanks for all the intel!!
Old Jan 15, 2023 | 01:28 PM
DIIDave's Avatar
For anyone that has done these repairs, specifically using silicone to seal the plastic sunroof frame to the metal roof of the vehicle, have you ever had to go back and remove the now “bonded” sunroof assembly/frame from the vehicle again? Is that possible without damaging the sunroof frame or roof? Thanks!
galahad
Jun 19, 2014 05:05 PM
macsrover
Apr 22, 2013 09:17 AM
mf0594
Mar 29, 2012 10:16 AM
Fivespddisco
Sights N Sounds
Jan 26, 2012 08:58 PM
Hussler737
Jan 25, 2010 09:48 PM
