Front sunroof problem
So, got into my wifes Discovery today on the way home. It was an odd 62 degrees outside, so I felt the need to ride with the sunroofs cracked. The only problem is, the front sunroof would not budge. The rear sunroof would raise up and retract back and forth, but I got nothing up front. Obviously not fuse problem. Tried that simple task already. And it wasn't stuck, it didn't make any noise like it was trying to move but couldnt, it just sat there. Has anybody had this problem? Any recommendations?
Thanks in advance,
Ryan
Thanks in advance,
Ryan
In one case it could be the switch...OR the mechanism for the sunroof is gone or struggling for some reason. Sometimes the tracks get dirty, but then you would still be able pop it up... so i guess thats not it. There might be a more in-depth look at this, but it sounds like the Sunroof mechanism or switch is out. here is the worst part:
I think sunroof mechanisms are pushing$1000... so you better hope thats not it.
How much do you like to feel the breeze?
Hello, You could rule out the switch by switching the working back switch with the front switch. If it works, it is the switch. If it does not work it is something else.
That's all I have.
That's all I have.
ORIGINAL: Disco Mike
Check for a front fuse, if that is good, then see if you can manually open it.
Thanks guys,
Ryan
Try to operate the roof manually, that will at least let you know if the motor, gears and tracks are OK. Also, use a test probe to see if you are getting power to the roof.
I popped the plate off, swapped the blue male connects behind the two switches and the rear sunroof worked but the front did not. So I know that the switch is good. How would I be able to "operate the roof manually"? Just push up on the glass? I don't have a test probe, is there anything else I can use?
Thanks,
Ryan
Sounds like the motor or sun roof it self has had it, there are places to buy good guaranteed used one,
http://www.roverlandparts.com/index....S&Category=370
By the way, never run off road with you sun roof open, it will fail and need to be replaced.
http://www.roverlandparts.com/index....p;Category=370
