Front suspension issue ~ 90k
Daily driver well maintained with 90k never taken off road starting to get a little steering wheel shimmy under certain braking and plenty of steering wheel responses on taking a seemingly minor hit from the crap roads in north jersey. Just wondering if there are common hits on consumables up there at this mileage? Track Rod Assembly, Drag link assembly, Damper, play in the steering or all of the above perhaps? Street ride is poor when I drive over a pebble and not confidence inspiring. Thanks
Factory springs and shocks usually wear out at about your mileage and your description fits this.
Address this first and go from there.
Hint 1: OEM replacement springs will give a factory like ride. Aftermarket heavy duty lift springs will give a "heavy duty" ride.
Hint 2: Don't put new shocks on worn springs. It will seem nice for a while but the new shocks will take a beating and fail prematurely.
new steering damper is needed. prolly more, as dave said; shocks and springs are tired.
have a look at your tie rod ends (I think rover calls them ball joints) on your track and drag. how are the boots, on them? with some type of pry bar (pickle preferred) is there a lot of slop in those joints? if so, it is usually more economically viable to purchase a hd set of steering rods than to fix up the factory ones. (fixed end on factory set)
Thanks guys, looking at RAVE the spring / shock job does looks like a few hours work on my back. I think I will go with the OEM standard springs not sure on shocks however for standard road use would like to try something better than stock if possible. When I'm under there I will get a feel for the ball joints you mention.
To check out the steering ball joints get someone in the driving seat without the engine running but with the key in position 2 and then they oscillate the steering wheel back and forth a couple of inches each way whilst you get underneath the front and hold the steering joints (6 in total) one at a time and it soon becomes apparent if one is worn. Also put a mechanics stethoscope on each ball joint and you can clearly hear it click or clonk when the steering wheel is moved to and fro.
I'm battling the EXACT same issue. So far I've replaced tires, HD springs, HD steering rods, and damper with no change.....hope it's not the case for you.
I've heard of some people tightening the steering box with the bolt on top??? Anyone with experience know if that could be another possible fix?
My understanding is that if you are only driving this thing on city streets you can take the steer damper out and make a hood ornament out of it. it's really only for wheeling to keep your steering wheel from spinning if you hit a big rock potentially breaking your thumbs.
Don't overtighten the screw but ensure it's loose first, tighten it until you feel slight resistance then back it off 1/8 of a turn and tighten the locknut ensuring you don't tighten the screw at the same time. Test drive for steering feel. Job done.
apcollin
06-11-2008 08:51 AM
andrewassur
04-09-2008 03:34 PM
