Front turn signal lights - newb question
I believe you mean "running lights", as opposed to "driving lights".
If someone's put a single filament bulb in there, that's probably the problem. I'm accustomed to that being a 2-filament 1157, on most cars, though I admit all the manuals I have handy are D2, and don't apply to your car.
Did you double check that the *socket* has only a single center connector?
i checked the socket, and its single.... wierd so they never did light up like driving lights only when i use the blinker? can someone verify off their disco 1 ?
EDIT ( okay verified that the socket is single type, but the bulb is a 1156 single filament ) So would a 1157 bulb fit on this bulb socket?
I don't think they were designed to come on as running lights. That is why the headlights light up really dim when you turn the switch to the running light position.
