Front wheel ABS Sensor Replacement
Old Dec 7, 2011 | 02:05 AM
sayeedA's Avatar
Default Front wheel ABS Sensor Replacement
Anyone successfully replaced the ABS wheel sensor? Mine sensor wire was damaged, ordered one should be here soon.
Any tip? Do I need to take out the wheel? what to look for?
Thanks
Old Dec 7, 2011 | 09:26 AM
Easy replacement, remove the tire, brakes and rotor and then look for the sensor wire, follow it to where it enters the hub remove and replace, make sure the o-ring stays in place and in tack.
Old Dec 7, 2011 | 10:19 AM
sayeedA's Avatar
Where is the 0-ring? Around the Sensor? You mean keep the old one on or is there a new one come with?
Thanks
KlamathMatt
Apr 17, 2020 05:27 AM
RANDY04D2
May 29, 2012 10:13 AM
twaszak
Jun 4, 2011 07:49 AM
