front wheel hub replacement
I have a 2004 Discovery that I purchased new and now use as a secondary vehicle. It currently has about 112,000 miles on it. I put between 2000 and 5000 miles on it annually and usually stay local.
The front wheel hub on the passenger side has gone bad and it needs to be replaced. I also need to replace the front brake rotors and pads. Does anyone have any experience with the wheel hubs on Amazon and made by TRQ (2 for $140)versus the one by British Atlantic (for $300)?
Note: I couldn't get the links to work.
Thanks.
Thanks.
The front wheel hub on the passenger side has gone bad and it needs to be replaced. I also need to replace the front brake rotors and pads. Does anyone have any experience with these wheel hubs on Amazon and made by TRQ (2 for $140)?
https://www.amazon.com/dp/B074817FN2...X027NFAV&psc=0
versus these by British Atlantic (1for $300)?
Discovery Series II Hub Assembly With ABS Sensor (Part # TAY100060)
Thanks.
Thanks.
For hubs, check out LR Direct, they are cheaper even with shipping
https://www.lrdirect.com/
https://www.lrdirect.com/TAY100060-H...keep_https=yes
Last edited by Friday Night Disco; 01-12-2018 at 04:30 PM. Reason: throttle body heaters are for wimps
i haven't had the pleasure of needing hubs yet, but when i was searching for abs sensors, and was under the impression that i needed an entire hub unit and not just a replacement sensor, many people recommened the cheap Ebay hubs and only good things to say about them.
Now, i havnt seen any long term reports with the Ebay hubs. i think the most mileage ive seen was around 10,000. so take that info with a grain of salt. if i were in your shoes, i would give them a shot. it should only take about an hour to change one.
Thanks. What's the difference between the different TAY100060 parts? For instance, TAY100060.C8 versus TAY100060.L8?
