front wheel hub replacement
Old Jan 12, 2018 | 04:22 PM
Newscotlander's Avatar
Default front wheel hub replacement
I have a 2004 Discovery that I purchased new and now use as a secondary vehicle. It currently has about 112,000 miles on it. I put between 2000 and 5000 miles on it annually and usually stay local.
The front wheel hub on the passenger side has gone bad and it needs to be replaced. I also need to replace the front brake rotors and pads. Does anyone have any experience with the wheel hubs on Amazon and made by TRQ (2 for $140)versus the one by British Atlantic (for $300)?
Note: I couldn't get the links to work.
Thanks.
Old Jan 12, 2018 | 04:24 PM
Friday Night Disco's Avatar
The front wheel hub on the passenger side has gone bad and it needs to be replaced. I also need to replace the front brake rotors and pads. Does anyone have any experience with these wheel hubs on Amazon and made by TRQ (2 for $140)?
https://www.amazon.com/dp/B074817FN2...X027NFAV&psc=0
versus these by British Atlantic (1for $300)?
Discovery Series II Hub Assembly With ABS Sensor (Part # TAY100060)
Thanks.
For hubs, check out LR Direct, they are cheaper even with shipping
https://www.lrdirect.com/
https://www.lrdirect.com/TAY100060-H...keep_https=yes
Last edited by Friday Night Disco; Jan 12, 2018 at 04:30 PM. Reason: throttle body heaters are for wimps
Old Jan 12, 2018 | 04:29 PM
KingKoopa's Avatar
i haven't had the pleasure of needing hubs yet, but when i was searching for abs sensors, and was under the impression that i needed an entire hub unit and not just a replacement sensor, many people recommened the cheap Ebay hubs and only good things to say about them.
Now, i havnt seen any long term reports with the Ebay hubs. i think the most mileage ive seen was around 10,000. so take that info with a grain of salt. if i were in your shoes, i would give them a shot. it should only take about an hour to change one.
Old Jan 12, 2018 | 04:33 PM
Thanks. What's the difference between the different TAY100060 parts? For instance, TAY100060.C8 versus TAY100060.L8?
Old Jan 12, 2018 | 04:36 PM
The manufactures and warranties
I went with the cheap britpart for both rear hubs with a 2 year warranty and zero issues after 7k miles.
Old Jan 12, 2018 | 04:44 PM
Okay, Great. Thanks.
Old Jan 12, 2018 | 04:52 PM
Whoa. Shipping costs from the UK for two wheel hubs are $48.
Old Jan 12, 2018 | 04:55 PM
Amazon might be cheaper...
Old Jan 12, 2018 | 04:56 PM
Saturnine's Avatar
Are you surprised at that cost considering they are probably heavy?
Old Jan 12, 2018 | 07:57 PM
Just thought they might be somewhat comparable to Amazon.
