Front Widows problems on disco 94
Old 06-22-2005, 04:59 PM
markwbball's Avatar
4th Gear
Default Front Widows problems on disco 94
1. my front pass and driverside window do dont work anymore? is there
a way to see if its a problem with the motor or the regulator or just
an electrical problem?
mw
Old 06-22-2005, 06:40 PM
mikemeyer0's Avatar
Default RE: Front Widows problems on disco 94
did you check fuse???
Old 06-23-2005, 03:58 AM
markwbball's Avatar
4th Gear
i checked the fuse.. its not the fuse.. if i hit the window button i hear a soft click noise from where I assume the windon motor would be... but nothing happens.
Old 06-25-2005, 04:31 PM
MikeRover's Avatar
It sounds like your window regulators are gone. I've had to replace two so far on my drivers window.
What happens is that the two little plastic wheels get deformed, especially if you are in a hot climate, and produce enough resistance to make the motor thing that the window has gone down so it stops.
All you have to do is take the door paneling out and you can see if they are deformed or not.
The first time, I purchased a completely new regulator while the second time I got a refurbished (new wheels) regulator.
It's an annoying but quite common problem with the Discos.
Old 06-26-2005, 04:08 PM
markwbball's Avatar
4th Gear
is there a place where they have a step by step instuction on how to open the door panel and check the regulator .. I am a student so I dont have that much money so I would rather do it myself.. or if anyone knows anyone cheap in the los angeles market..
mw
Old 07-11-2005, 09:42 PM
bluerover2002's Avatar
If your back windows work and your front dont, then take all four door panels off-Unscrew the door handles, unbolt the hand grips, then pop off the panels. Take the regulators from the back doors and put them up front making sure to switch sides (the rear left and front right are the same regulator, and the rear right and front left are the same). Stick a piece of wood inside the rear doors to hold those windows up securely before putting the panels back on. Now at least your front windows work and it didnt cost you a penny. I hope for your passenger's sake you have rear air...
Old 07-12-2005, 10:38 AM
duboff's Avatar
as you can tell. lots of people have had the same problem. Another sourse to consider is a salvage yard. rovers and salvage yards are not to familiar. it is worth a shot. the problem is 99% a regulator. duboff.
Old 07-12-2005, 10:05 PM
ORIGINAL: duboff
i think you meant to say unfimilar
Frank4
03-21-2014 05:21 AM
georgep
05-23-2012 04:28 PM
JBeezy53
02-22-2010 11:14 PM
vernmangk
LR2
02-21-2008 09:23 PM
DiscoOfDoom
10-21-2007 09:22 AM
Quick Reply: Front Widows problems on disco 94
