Are front window switches interchangable? 2003 Disco
Old Aug 12, 2009 | 07:07 PM
USMC_Denver's Avatar
Default Are front window switches interchangable? 2003 Disco
So I left both roofs open yesterday, and it rained. Hard. Gave only 10% chance.. but whatever. Today, my driver side window doesnt go down. All other window switches for fine. So to isolate the problem, so the switch, or motor, can I take the right window switch, and put it in the left spot and try it? It looks like you can, because the link just has console switch, and rear switch. Not left and right. Just wanted to ask before I went thru the trouble. Common sense tells me yes, just want to be 100% sure.
http://www.roverlandparts.com/discov...witches-1.aspx
Old Aug 12, 2009 | 07:27 PM
Yes you can swap the switches, all they are is a on off switch.
Hell, you can even swap the rear switches for the fronts.
Old Aug 12, 2009 | 07:37 PM
I came back here to edit my post, because it took more time to write the post, than to do it. But Ill let my retardedness stand. Just swapped them out, window works now. Switch just must be bad. So Ill order one for $20, and chalk it up to a lesson learned.
I am about to make a thread about door locks though, driving me crazy.
Old Aug 12, 2009 | 07:58 PM
Ah yes, door locks...
Have you tried opening up the bad window switch yet and drying and cleaning it?
Hell man, its already bad so what do you have to lose?
Old Aug 12, 2009 | 11:09 PM
AK Rover's Avatar
We all have those moments of DUH now and then.
Old Aug 13, 2009 | 05:32 AM
No, but I will. Thanks for not laughing. At least not where I can see it.
Broken08
Feb 14, 2015 11:17 PM
03discoman
May 13, 2010 08:26 PM
scottbly
Mar 16, 2010 08:30 PM
tlbslc
Oct 23, 2009 06:18 AM
LordOphidian
Jul 20, 2006 06:29 PM
