Frozen door hinges
Old Jan 7, 2018 | 02:48 PM
Fastercat's Avatar
Default Frozen door hinges
Is it common for ice to build up behind the front by door hinges? This is the second time this year I’ve already had to clean them out.
Old Jan 7, 2018 | 06:30 PM
JUKE179r's Avatar
I don't get that here in Georgia.
Old Jan 7, 2018 | 08:02 PM
shanechevelle's Avatar
That's really strange...
Do you have leaking sunroofs?
rain gutter installed?
Old Jan 7, 2018 | 09:00 PM
number9's Avatar
Looks like drainage from the cowl area that's frozen into puddles. Probably not normal (?) to puddle/freeze there and you could have some debris or ice dams diverting the normal flow.
Old Jan 8, 2018 | 04:01 AM
Fastercat's Avatar
I’ve sealed my sunroofs over with removable silicone so it’s not them, I’ll take a look around the cowling.
Old Jan 8, 2018 | 05:13 AM
OffroadFrance's Avatar
I have found the rubber door seal freezes or even the lock mechanism to the door but never the hinge. May I suggest that you park with the rear into the wind and the front slightly pointing uphill if possible. Also if possible park the truck in a garage or barn away from the snow and ice. Try spaying the hinges with some WD40 or antifreeze (if it's non corrosive)
Old Jan 8, 2018 | 03:57 PM
Fallstaff's Avatar
Lol. I was about to post what are nearly identical pictures. We both have the same running boards by the looks of it. I think maybe they allow it to start backing up and then it’s just drip drip drip and it builds up.
It can be dangerous with a long period of the wrong weather - that ice jam can fill the space entirely and you don’t notice until you use the whole leverage of the door to bend the bottom corner. I’m surprised that’s not damage I see more. Must keep an eye out for it.
Rover_Hokie
Nov 2, 2016 06:10 PM
Paul Grant
Feb 24, 2012 01:12 PM
Camdisco24
Jul 9, 2011 10:03 AM
CANAMDiscovery
Jan 30, 2010 09:20 AM
VikingDiesel
Sep 27, 2009 08:27 PM
