Fuel door latch alternatives? [PICS]
Old Sep 19, 2009 | 06:07 PM
Torancis_LR's Avatar
Default Fuel door latch alternatives? [PICS]
I just purchased a fuel door latch from AB and the little plastic part snapped when I was trying to attached the thing. My old one is flimsy and will not keep my door close.
Does anyone have a trick for these to stay or to put in on the door? There got to be some alternative way to keep the door close, this is a faulty design by Land Rover.
Old Sep 19, 2009 | 06:12 PM
sloppyjoe's Avatar
duct tape =)
Old Sep 19, 2009 | 06:14 PM
Originally Posted by sloppyjoe
duct tape =)
That's what I'm using in the same time
Old Sep 19, 2009 | 06:16 PM
sloppyjoe's Avatar
hahahahahahahaha success!!!
if it were me i woulkd take that plastic piece to a machine shop and have a lightweight aluminum piece made or something from a higher strength plastic
Old Sep 19, 2009 | 06:36 PM
Urban Panzer's Avatar
I bought 2 when mine was duff, good job I did as 1 broke as I fitted it. it def is a crap design and not very secure. Im currently thinking of either using a lock assy from a D1, or fitting a locking cap to
Old Sep 19, 2009 | 06:53 PM
Gorilla Glue.
Old Sep 19, 2009 | 06:54 PM
sloppyjoe's Avatar
boogers
Old Feb 15, 2017 | 06:34 PM
nmacej's Avatar
Magnets my friends! Magnets!!!
Head to Home Depot, and grab a $4 packet of cabinet door magnets. They come in different strengths, I recommend the 16 lb. set. The set up is a high power magnet which sits in an included fitting. Said fitting has a hole in the back for an included wood screw to pass through for mounting in the cabinet. I replaced the screw with a 4/40 bolt/washer/nut combo and mounted it right the the metal latch (in place of the crappy plastic latch). I then used some Guerrilla Glue to mount the second magnet and fitting jut behind the actuator. Be sure you have the polarity right, or it will push the fuel door open vs holding it closed. And Viola! No more thinking about a crappy plastic clip that keeps breaking and popping off. Does it lock? Definitely not. Could you pop the locked door open before with slight pressure and a key? YEP! So I wouldn't worry about the security aspect. Anyway... There you go. That's my fix.
Old Feb 15, 2017 | 08:41 PM
Friday Night Disco's Avatar
congrats on bumping possibly one of the oldest threads
Old Feb 16, 2017 | 10:55 AM
Jsivey's Avatar
I've actually ordered 4 plastic clips from AB, but could it also work to cut a small hole in the metal "latch" and have the actuator pin lock into that? It would have to be really accurate and just the right size or the door would wiggle, but it seems that it could work.
Either way, I'm trying the plastic latches first.
