fuel infector cleaner
i think i am having fuel injector problems on my 02 Discovery,
At first i thought it was the pcv valve, "when at an idel it sounds like it is starving and spudders ever so often, then after a while the service light came on, a day later it went off.
i went to get a pcv valve at O' rellys and they said the dealer has not released that part yet.
"Accually my wife went to get the part and that is what they told her, I was working out of town. anyway, i need to get that part, any suggestions, and i would like to put a injection cleaner in the fuel, any suggestion, i heard "sea foam" was good stuff
any input would be great
thanks
thanks
I'm not sure that you've got problems with the fuel injectors. Discovery with Td5 engine has these problems and the only explanation is CABLES. I think you have to change the injectors cables. These cables are in the engine. Just remove the cover of the enjine and you'll see these cables, buy another one complect cables, clean the cables connector with WD-40. Then remove Engine ECU /it is in the area behind right main lamp/ check the ECU's connectors /probably there is oil from the engine/ clean them and your engine will be all right.
wish you luck!
wish you luck!
i replaced all the spark plugs to day and the problem seem to go away
it seem to have a very little sputter only on idel. the guy at autozone pluged in the little computer and it said plug 1 and 6 missfire
or fuel filter or fuel injector or vacum leak
in that order
so i replaced the pluges and bought a new fuel filter.
I cand find were the fuel filter is located autozone sold me what looks like a generic one off the shelf . i dont even know if it is right.
i thought it would be located behind the R/R tire but i cand find anything that looks like theis
please HELP
in that order
please HELP
DeepBlueWater
10-15-2007 07:38 PM
