Fuel injector clamp and trans pan bolts?
Old Sep 10, 2016 | 08:58 PM
cta's Avatar
cta
Default Fuel injector clamp and trans pan bolts?
I changed my transmission fluid and filter today and managed to break one of the bolts. I found a ton of posts on removing said bolt but nothing on what size the replacement is. I'd like to avoid driving to lowes, pulling a good one to use as the template and reinstalling prior to driving away. Anybody know the size?
I've also been having a fuel injector open circuit and misfire code problem. I was mentally preparing to pull the manifold and rail when I decided to take a look at it with the scope today. Turns out the clamp that holds the wiring harness to the fuel injector is missing. I can recreate the codes by lifting it on and off using a long screw driver. Only problem is I have no idea what this type of clamp is called or where to buy one. Its the same type of clamp whcih holds the plug on the purge canister. None of the common parts suppliers seem to have them listed and they aren't in rovers north parts picture. Thoughts?
Thanks
Old Sep 11, 2016 | 06:25 PM
cta's Avatar
cta
If anybody else ever happens to search for this the transmission pan bolts are m6 x 40mm. Still haven't figured out the injector wire clamps yet.
Old Sep 12, 2016 | 12:22 PM
meat's Avatar
what was the issue with the bolt? corrosion?
Old Sep 13, 2016 | 09:52 AM
cta's Avatar
cta
The bolt snapped off during reinstallation. I didn't really apply much force to it so I think it was already somehow damaged. I took a closer look at the other corner bolts as I pulled and replaced them and noticed 2 of the 3 were slightly bent. Something must've been wonky during a PO's installation.
erick846
Dec 1, 2015 11:19 AM
0304Disco
Oct 15, 2012 05:16 PM
MrFlea1
Jan 25, 2012 10:58 AM
hummermaniac88
Freelander
Jul 5, 2009 02:08 PM
starcraft
May 11, 2009 02:20 PM
