fuel line connects ??
Old Oct 11, 2008 | 07:14 PM
redhotbuzz's Avatar
Default fuel line connects ??
If your fuel pump is goonago out thank G it was my driveway...I got PB blast all oer conectioins. Im ready to replace fuel filter, peice of line under drivers side rear,, and Damn my fuel filter.. The fuel line connections are leaking due to rust,,,,,,,,,,,,,,,,,,, I need a fix ...thanks
Old Oct 11, 2008 | 07:47 PM
Default RE: fuel line connects ??
What connections exactly are leaking?
Old Oct 11, 2008 | 10:57 PM
redhotbuzz's Avatar
Spike.. The terminals that hook on the fuel pump runiing off the fuels lines are rusted and one is weeping I need new ones.........>YO ouuta be in here... Im trying to do the master pump deal and just switch out the pick up hose..Im pretty sure I got a 4.0 sfi but there was a question about the vin number.. and the pump pressure being 33-38 Any help appreciated Thanks all
Old Oct 11, 2008 | 11:07 PM
It will say right on the intake plenum what engine you have. The 3.9 and the 4.0 are the same engine, the only real difference is the EVAP system. Depending on your EVAP will depend on the fuel pump.
You might need to replace the fuel line.
As for the pump PSI, I am pretty sure that you are right on par with what you have.
Old Oct 11, 2008 | 11:17 PM
redhotbuzz's Avatar
Do I have to drop the tank to replace lines??
Old Oct 11, 2008 | 11:29 PM
I do not know if you need to drop the fuel tank or not.
You might beable to put it all together and then seal it somehow so that it no longer leaks.
I do not know without being there how bad it is. But if the fuel line is completly rusted you will have to replace it. I do not know if you can splice it or not.
aftermath431
Jul 13, 2024 12:40 PM
Xrover
May 21, 2013 10:04 PM
JerrodSteph
Jun 12, 2011 06:04 PM
JumPeR04
Apr 7, 2011 09:52 PM
