Fuel mileage
Old Nov 23, 2007 | 10:50 AM
Landzu's Avatar
Default RE: Fuel mileage
ORIGINAL: 03springer
My Rover is a weekend machine whichdoesdouble duty. On and off road. Had it 2 weeks ago on a club function which I was amazed what it could do. It is totally stock. But found out I do want a lift and better tires right away. { Bashed in front air dam }[:@]
With off road tyers your mpg will suffer.
Not stock any more, "bashed in front air dam" time for the ARB.
Old Nov 23, 2007 | 11:17 AM
Darover's Avatar
Holly shoot, you guys get 1 1/2 times the mileage I get with the same amount of fuel. It's true that mine is driven all week in morning and evening traffic, and week-ends to run errands, but that's still unbelievably different.
Old Nov 23, 2007 | 12:25 PM
03springer's Avatar
Darover,
Did you do a induction cleaning on yours? Cleaner in the tank? It`s the little things sometimes that make the big differances. I`m not worried about how many miles per gal I`m getting I just wanted to know how many miles I could get out of a tank of fuel since my fuel gauge doesn`t work right. I have Magnecor wires and the fusion plugs to install, but i`ll wait untill I actually need them.
Old Nov 23, 2007 | 01:54 PM
Darover's Avatar
I got the plug wires, the new plugs, sythetics everywhere new O2 sensors....a lift and 31 inch tires(265/70-16) which create a 6% speedo and odoerror, and I'm not a fast driver by any means. Last tank, I got 12 m.p.g
It's true that its 80% morning and evening traffic with the rest highway. but, unless using the heated seats ( mornings are cold up here now)causes bad fuel economy, I can't explain why I went from 14 m.p.g to 12 m.p.g after changing my front O2 sensors with new o.e.m ones.
Old Nov 23, 2007 | 02:23 PM
03springer's Avatar
Taller tires should help in fuel economy. New 02 sensors are supposed to help too? Baffeling aint it? Or wait, Aint aint a word is it? LOL
Old Nov 23, 2007 | 02:37 PM
Darover's Avatar
No it aint ! I really can't explain it. Unless it has to do with the aftermarket y-pipe that was installed by the previous owner. When dealing with a gasket problem, I had removed the y-pipe, and had found that the entranceseemed to bevery restrictive. Other than that, my O2 sensors are new, so I guess that if the cats were kaput, I'd get a code.
The truck rolls pretty smoothly when driving, therefore I don't think that the brakes are rubbing causing a resistance. And the tires are inflated to 34 psi front and 38 psi rear.
So I really don'tunderstand what could causeother people with the same truckto getup to 4 more miles per gallon.
Old Nov 23, 2007 | 03:10 PM
03springer's Avatar
I actually run 28psi in front and 38 in back. When I ran the fronts higher I would get a front end wobble. Sticker on door says to run them at 28 on front. Thats where I`m at. I`d like to get a roof rack so it will make fuel mileage go down. But hey, Its only fuel right??
Old Nov 23, 2007 | 03:32 PM
okdiscoguy's Avatar
ORIGINAL: Darover
I would guess that your regular station started mixing Ethanol up to 10% about the time you changed the O2's. Just a guess, but it will kill your mpg by 10%
Old Nov 23, 2007 | 03:44 PM
Landzu's Avatar
With the cra-,, ethanol I lost 22% in town and 9% hwy .
I DO NOT LIKE ETHANOL, LESS OF EVERYTHING
but cost.
Old Nov 23, 2007 | 04:49 PM
Disconoobie's Avatar
I was trying to find a link, map, anything that showed ethanol use by gas station is my area, but came up empty.
...anyone know off-hand which gas station companies as a rule use ethanol and which don't?
