Fuel/misfire/starting issues
Hello,
I have a 2001 disco SE.
I have had off and on starting/running issues
Starting issues:
At first no fuel no spark, replaced crank sensor and would start well but still underpowered.
Replaced spark plugs, still had running issues
Drove for a month or so as is. Then had a starting issue again, this time no fuel. Replaced fuel pump. Running issues persisted but no starting issues for about a month or so.
This week replaced headlights and nothing else. No fuel.
Running issues:
P0300
P1300
P0301
P0306
Misfiring, checked gaps of all plugs, cylinder 6 had a really dirty plug all others were clean.
Current starting issue troubleshooting:
Inertia switch is working
Vehicle does not seem to be immobilized (no led flashing and getting spark)
Fuel pump relay in engine compartment fuse box is working
Fuel pump plug only has power to purple/white wire and only when cranking
Took out the new crank sensor and cleaned (wasn't dirty) and it didn't fix it.
Any suggestions would be greatly appreciated
Starting issues:
Running issues:
P0300
P1300
P0301
P0306
JumPeR04
04-07-2011 09:52 PM
