Fuel Pump
Hey guys I'm new to the forum and thank you all for posting such great material. I recently had my rover die on the freeway..turns out there was no gas in the tank when my dashboard was telling me i had a quarter of a tank.
so i was wondering if you guys think i need to change out the fuel pump, from what i understand there is a sensor on it that sends the info to the gauge?
also if i do decide to do a fuel pump removal what is a good aftermarket option. I've seen pumps range from 200-400? I'm currently in a 04' land disco II
thanks for the help
thanks for the help
thanks for the help
thanks for the help
Had an issue with mine a few months back. Get a new ring for it and lift the carpet up in the rear and undo the cover plate. Mine was hung up on one of the lines in the tank so it wasn't reading correctly. After I pulled it out and moved the line, put the new ring on the fuel pump and reinstalled it, worked like a charm.
Travelor
Sep 24, 2015 06:11 PM
JumPeR04
Apr 7, 2011 09:52 PM
atikovi
Apr 7, 2007 03:27 PM
