Fuel pump options
Old Jul 23, 2012 | 06:47 PM
br0keit's Avatar
Default Fuel pump options
It has been suggested in another thread I posted that my fuel pump may be on its way out. As a recap, after my truck sits for a while it seems to have a slightly slower startup (maybe an extra turn or 2) and has no power for the first 30s or so of driving. Power seems to step up little by little rather than just kick in. It is accompanied by some popping sounds from the front driver side area. It also has weaker than usual acceleration even in "sport" mode.
All that being said and seemingly pointing more and more to a fuel pump....what options do I have? Is a used pump too much of a risk tho its cheaper or should I go pay the $380ish for a new one from AB? Or is there a cheaper place I can get a reliable one? Also, how do I find out for sure if mine has the evap pressure loss sensor?
Old Jul 23, 2012 | 07:49 PM
Go to AutoZone and check their price, thats where I got mine.
You can tell the evap code by your VIN#, look at fuel pumps on AB's web site, it will list 2 different pump's for your truck and will tell you which VIN needs which pump.
Old Jul 23, 2012 | 09:13 PM
jfall's Avatar
IF you are cagey, you can read the OEM brand and part number off of the fuel pump
itself.
Google for it.
And then just replace that part.
Will take a lot of skill.
The advantage of replacing it all is that the gas gauge will read correctly with the new innards.
Old Jul 24, 2012 | 04:28 AM
br0keit's Avatar
How much time and headache and cost would it be to get the sender re-calibrated when installing a full new unit? Is there a chance it'll work plug and play or am I definitely going to have to find a shop?
Old Jul 24, 2012 | 07:14 AM
drowssap's Avatar
Before you go buying a fuel pump have you put a fuel preasure guage on it yet?
Old Jul 24, 2012 | 08:48 AM
I agree, do a fuel pressure test first.
As for buying a used pump, you are buying a used problem.
Most part stores have just the replacement motors, made by Airtex, for around $70 you can fix the problem.
Old Jul 24, 2012 | 04:42 PM
br0keit's Avatar
well its obviously a pressure issue of some sort (if that's caused by the pump I don't know). Today when my truck was trying to climb a highway hill with cruise on at about 70mph it started stuttering, I thought it was going to stall so slowed down to get ready to pull over then it stopped and what little power it has came back.
Old Jul 25, 2012 | 07:35 PM
br0keit's Avatar
Sorry to double post but, does anyone who has replaced the motor only happen to know the part number?
Old Jul 26, 2012 | 07:00 AM
drowssap's Avatar
Airtex E3270 - BUT DOUBLE CHECK THE FITMENT BEFORE ORDERING
Old Jul 26, 2012 | 07:44 AM
A 3270 will work well.
