Fuel Pump Relay
on
RE: Fuel Pump Relay
Just so you know, you only need a 12 volt test prob to test for voltage at the pump. Have you checked the fuse?
The pump will only run for 4 to 5 seconds and then shut of if the engine does not start.
Not know what year D1 you have, but have you checked the cam sensor, if it is bad it won't send a signal to the ECU to fire up the fuel pump.
