Fuel Pump Relay
RE: Fuel Pump Relay
you need to find out if you have power and ground at your pump, if so, the pump is bad, if not it could be the fuse, the inertia switch, the relay or any of the related wiring, cam sensor will not cause no fuel pump opperation, just no injecter opperation until it defaults and runs off the crank signal... anyway, get a testlight and a wiring diagram, and see what you have
Travelor
09-24-2015 06:11 PM
