Fuel Pump Relaylocation
Old Dec 6, 2006 | 01:00 PM
MONTANACW's Avatar
Default Fuel Pump Relaylocation
Where is my fuel pump relay located on my 1997 land Rover Discovery V8
Old Dec 6, 2006 | 02:44 PM
hoberock's Avatar
Default RE: Fuel Pump Relaylocation
It is on the fender support under the hood on the passenger side. It is on a bracket with another relay. Near the ECU. Basically, if you go to the center of the support you'll side a big, black plastic "box." It located from the box towards the firewall. It is in the factory manual under the 19-5 if you have it. If you can't figure it out, let me know.
Tim
Old Dec 7, 2006 | 12:03 AM
Are you having a problem with the relay, whats going on?
Mike
Old Dec 7, 2006 | 12:24 PM
MONTANACW's Avatar
This Disco is is fantastic condition, has had all its services, every 30k, engine runs so smooth you have to look at the tach to make sure the engine is even running it has 91K on it and I am the second owner I think. Anyway, sometimes when I start the Disco, it won't start, but if I cycle the key 2 times then it starts right up. I have changed all the plugs, wires, fuel filter, oil, ecm coolant temp sensor, and the fuel temp sensor. The Disoc has tons of power, so I wanted to check out the fuel pump relay. I think I found it, is it a black box with two connectores on the bottom ?
Should I replace the fuel pump too
Old Dec 7, 2006 | 01:47 PM
What you are describing is not a relay problem. It is the valve assembly in the fuel pump that is designed to maintain fuel pressure when the engine is turned of. I believe yours is allowing the fuel in the fuel rail to bleed back into the tank so your engine has no initial fuel to start on that is why you have to prime the pump by turning the key on and off.
Mike
Old Dec 7, 2006 | 01:51 PM
MONTANACW's Avatar
THANKYOU!
So would you replace the fuel pump, or wait? is it comon for the pumps to fail?
Old Dec 7, 2006 | 02:40 PM
It will not leave you stranded, may get worse with time but won't cost any more now then later.
Mike
Old Dec 7, 2006 | 02:48 PM
MONTANACW's Avatar
Thanks again for your help!
I am hooked on these Land Rovers, why did I wait so long to get one???????
Old Dec 7, 2006 | 06:22 PM
Hey, it is time to go play with it now.
Enjoy your truck,
Mike
Travelor
Sep 24, 2015 06:11 PM
JumPeR04
Apr 7, 2011 09:52 PM
leadfoot
Sep 13, 2009 09:51 AM
discoken
Nov 4, 2008 12:39 AM
