fuel reset switch - now won't start
Ha. Well we'll see. The truck starts right up, but I just moved it only to apply a little rust bullet under the battery tray which had corroded a bit.
So I'll wait until that paint dries, then put the battery back, *then* start up the truck and let it get hot and see if the problem is fixed. (I know, I know, I've violated the prime directive while troubleshooting: "fix only one thing at a time."
It's a true-ism at my house - there's no such thing as "1/2 hr in and out." :-) Once I decide to work on the vehicle, I'm pretty much at it all day.
S'long as y'all bear with my verbose postings, I'll post here again with the final answer re: "did the new CKP sensor fix it?"
Well just to finish out the thread - that crankcase sensor is a bear to access. You need to go in from both above and below - above to get the connector off and from below the remove the heat shield and the sensor itself.
Reaching high up past the exhaust manifold that just barely lets your arm through gets old really fast. :-)
But if your hazards aren't flashing, then it's no the inertia switch.
found it. it didn't help. The switch looks nice and clean. I have an iLand Diagnostic tool coming soon that I hope will help me narrow down the problem. I found one 20amp fuse that looked bad and replaced it. Swapped the Fuel Relay with one of the others, don't know if it was bad. Probably not. Didn't work. I don't know if I am getting any fuel to the engine or not. Perhaps from the new battery getting weaker from all the start tests I am showing the green M and S lights blinking. The shift indicator (little red light) is blinking when in Drive position. I suspect that it could be wires from the Crank Position Sensor which are back behind the engine and impossible to reach with out taking off the intake manifold and valve covers, possibly even the heads? I don't know what else to check with out the diagnostic tool.
It's kind of easy and a pain to get to the Crankshaft position sensor.
The sensor is located near cylinder 7 and you don't have to take off the valve cover or the heads.
It's a cover with a couple of bolts and unclipping of the connector to replace it. reinstall in reverse order with a "BOSCH" sensor.
I've done it twice already in the past 2 months and got the process down now.
1997, ckp, crankcase sensor, disco, discovery, freelander, fuel, good, inertia switch, land, replacement, reset, rover, spark, start
