Fuel saver chip and installation
Found a fuel saver chip from eBay.Basically it's a resistor type of chip to me and it short the air flow sensor to give ECU a consistent fake signal, as I can read from the instructions. It claims it will add 10-20hp in power and save the gas by adding 5-10mph. So two questions:
1. Has any of you ever used that before? If so, what's return result?
2. How to get it installed on a 2003 Discovery, as mine one is using an air flow mass unit, I can't figure out which wire goes to intake air sensor.
Thanks!
Thanks!
I'd like to give it a try and see. Can someone tell me where I find the two wires from the intake air sensor. I have about five wires from the mass air flow module, but don't which two come from the intake air sensor, that where I need to plug in the chip.
Thanks,
Thanks,
