fuel smell
On DI's the fuel filler neck can start to leak from age.
It wont leak alot, but just enough to give you that gas smell if you stand at the back of the truck.
If it happens only when you start it and you can smell it from inside the truck look into a full carbon canister, which means you have a clog in the EVAP system.
Yes, It's absolutely from the fuel filter joints or may be from the pipe line which connects from the tank to filter, there should be minor hairy crack in the pipe line. But it won't appear as wet.
Good call Tom, I forgot about that one.
